- Joined
- Jul 23, 2011
- 51,915
will look on a model of an aluminum pod for the rigging tubes. may be tomorrow by the time I get the info
deck plate. how big is your arm near your shoulder. Armstrong has their own (doesnt use a mounting ring) and the ones with a mounting ring have a smaller opening.
fiberglassing the inside - gravity is your friend. I suggest fiberglass the low flat surface wrapping a bit up each side, cure, turn the assembly 90 degrees, rinse and repeat I would do a good 1/4" or more on the inside (thicker at the joints)
openings in the bulkheads help with access.
