- Joined
- Mar 8, 2009
- 43,921
Merc Flow Torque prop hub uses 3 washers and a self locking nut. The only one so far that isn't just a flat washer is the bevel (or conical) type. All dimensions are accurate except for maybe the Height. My caliper's jaw was not made so I could get to outer edge of each side. I should have layed it flat and used the depth to get it, but reinstalled and don't want to take it back off unless needed
So I'm looking to find where these can be obtained. The other flat washers will not need to be replaced, and with a Nut and washer kit 840383A2 cost of $50, I'm looking now to see what can be found
