1982 starcraft v220 mariner v5 potential rebuild
Crabeye
I need to order some solid rivets for the v220 mariner! Who has the experience of what i should order and where to get them...also the most effective tool to use to hammer them in place?
MNhunter1
Check out Watermann's sticky at the top of the Starcraft forum...
Crabeye
Im ready for rivets!! Weather is good..looks like about 50..all we're rivets that were trapped by trailers carpeted bunks.!! All foams gone..looks pretty clean,even before pressure wash..
redneck joe
Thats about then I started to get happy. Do you have the floor peices all ready?
Crabeye
No floor pieces ready..but old ones are in 1 piece so should be easy..I need to order rivets..who has best seller..and need gun,bucking bar,and tip
Crabeye
I need to just do it!!!!!!! Im procrastinator and am looking for other projects...who has a V220 supermariner center console and how good does it handle big water..
redneck joe
Dad had a 79 21 mariner when i was a kid, now at 60 years old I have an 82 18 footer
Also, I didn't buck i would not have had help so I just used lots of 5300 with my approx 375 closed end rivets.
MNhunter1
Check out Aircraft Tool Supply(ATS) and some of their 4x rivet guns. I've been happy with mine. Tried it with the air hammer, which was fine for a couple of solids, but if you're going to be setting more than just a few, it's well worth the investment.
Watermann has a excellent sticky at the top of the forum on everything rivets if you haven't read through it already: https://forums.iboats.com/threads/rivets-rivets-and-more-rivets-repaired.741809/
Crabeye
Hi..will do that..I just ordered or am set to order some solid rivets...reading the recommended rivets to use on my 1983 v220 supermariner..I think that's what it is.lol...from reading prior post I am double checking from those that have done it..my selection of rivets so far is 3/16 brazier head rivets in 1/2 inch long 7/16 and 9/16..maybe I should get 3/8 long? Main question is the softness..guy is trying to tell me I want 1100 soft cute aluminum..I remembered reading an alloy suggested hardness one..is anybody can come back and tell me which one..or give me a shopping list
Crabeye
Getting ahead of myself here...thinking about the flotation!! I know I've seen the ideas...now that im down to it...what is the BEST way? IM LOOKING FOR SOME RECOMMENDATIONS
Watermann
1100F which is pure soft aluminum and 2117T4 which is a strong alloy. The hull AL material is 5052 alloy. I would not recommend using 1100F pure soft AL on structural components such as the ribs.
Crabeye
WELL...I am ready to get said rivets set and now have just acquired a 21ft. Duckworth welded boat!! So beleive i am going to put my 1983 Starcraft V220 supermariner up for Sale..now I know that my boat is a very rare model and this one is in pretty good rebuildable shape..Transom is good ,no big amount of corrosion..I stripped out all foam,inspected everything and it appears that just rivets that we're sandwiched between boat and trailer bunks heads were flaky...those rivets are tight just heads compromised...drilled a few out..pretty easy project ..So saying all that what would be a decent price to put on that boat to sell? Thanks Crabeye
Crabeye
UPDATE!!!! I Have boat floor of,stripped of foam,ready to rebuild and just acquired 21 ft Duckworth turnkey..Have decided to sell...So 1983 Starcraft V220 SuperMariner Center console..Very Rare..So anybody interested..get back to me...Also any experts let me know what i should be asking ?
