1962 evinrude fastwin on a 1236 aluminum john boat motor height.
airshot
Update got a welder making a bracket so I can raise motor .Im going to try that
Hopefully that will also strengthen the transom as well. That much weight and hp will weaken the transom over a short period of time. If you have any pics of the motor on the transom they might help us make sugestions.
Chrisham
Here are pictures .I raised it 2 1/8 inches. Now with the pin in the first hole the front of the cavitation plate is slightly lower than the bottom of the hull.When adjusted all the way back it is slightly higher.Im going to try the second hole first..mI just redid the transom.
airshot
With the cav plate parallel to the bottom of the boat ( disregard what hole it is in) is the cav plate above, below or right at the bottom of the hull ? Once that height is set, now you can trim to get the best ride. Do you have a fact for the engine ? Don't over rev, or you might be buying another motor !
It does look like it would be a fun toy !
Chrisham
With it in the first hole it is about level with the bottom of the boat.If you go to the second hole it will start bouncing at full throttle.I might have a tack at the shop .What should it be turning.Whatever it's turning it is plenty fast now.When I try the 25 on it it will probably be to much now.I suspect it was lower than the boat also and losing power also but had enough horsepower that it didn't matter
airshot
A 25 hp motor would be an accident looking for a place to happen, way to much ! If an accident were to happen, you would be sued for negligence!
10 hp would be maximum if the boat is rated for that much.....
