being an ETEC look at the side LEDS on the EMM (CPU) when you run the engine. report findings top to bottom leds at
KEY ON....
Running.....
motor may be entering SAFE mode with max rpms around1800 due to a sensor fault code!!
to service ETEC you should get EV diagnostics to look for trouble codes. latest SW is ver. 5.9
EVINRUDE DIAGNOSTICS VERSION 5 A GUIDE TO GETTING STARTED September 2021 INTRODUCTION This guide is primarily intended to help Evinrude E-TEC owners. The words...
docs.google.com
suggest you consult with the ETEC OWNERS GROUP
www.etecownersgroup.com
download your manual look up back pages for trouble cause options
drive.google.com
