[SPLASHED] I/O (Sterndrive) Conversion to Outboards
Pmt133
Is it just an optical illusion or does the extension have a slight hook to it?
And you don't see that side anyway! Looks good
tpenfield
I thought that it might have a slight downward angle to it. Maybe an 1/8" of an inch . . . But I have not put a straight edge on it to check.
If it does, it will be deemed a feature (stern lift) rather than a defect. :ROFLMAO:
alldodge
Looks good, and after the bottom paint goes on and motors installed, folks will be looking at the motors
Ted, when it comes to fairing, it's about practice, and the right tools
aspeck
Ted, from Central PA it looks great! And remember, the imperfections that you see will never be seen by a blind man riding a horse in the middle of the night, so all is good!
Ted, if it really bothers you, scuff the extension, mix up some gel paste, and spot fill the low points with a putty spreader. Then hit the extension with 330 grit, then 400, then 600 then 800. Then polish
Most of the imperfections should disappear
tpenfield
Not worried about the imperfections . . . there will be time in the next off-season to make things pretty.
Meanwhile . . . I checked in with my re-power guy and some of the parts for the re-power are coming later than expected, which gives me a few more days to do finishing touches.
Today was lower the boat onto the trailer day . . . It had spent the winter up off the trailer, but still over it. I had moved the trailer forward about 2 feet to address the tongue weight overage when I took the engines out.
Laying the trailer back down showed that the tongue weight was really low 350 ish. So, back up went the boat and the trailer was slid about 15" back. Tongue weight was still low, but better
The day was still young, so the next big thing to do was put the seat assembly back in(on) the boat. It is a fairly high lift and the seat is wicked heavy. Connecting the hinges is a nearly impossible task, which will be top of mind in the AM.
Some of the parts for the re-power are arriving later than expected. So, the boat will be going in on Thursday instead of Monday. This will give me a few more days to finish up a few things.
tpenfield
Now I am sure some have been wondering about the gap on the sides of the extension bracket.
My plan is to put stainless steel 'straps' in those gaps which will attach to both the boat and the extension bracket. Functional and somewhat decorative.
I have some 316 bar stock on order and will fabricate a piece for each side.
tpenfield
Progress update . . .
I got the underwater areas barrier coated. AF paint to follow.
Also, the mechanical's and wiring in the bilge are done.
I ended up putting the main bilge pump in the exact same place as it was. Two secondary pumps are more towards the transom.
tpenfield
Getting closer . . .
I got the bottom painted with anti-fouling paint.
The wiring in the bilge is pretty much done . . . ripped out a bunch of wiring that no longer had a home. Still got blowers :D
The gelcoat came out chalky . . . probably due to my air compressor not being up to the task. I may do another coat using roll & tip and a high % of the Duratec Hi-gloss.
