New Journey
MNhunter1
How did you mount the trolling motor on the front? Looks like you used spacers to make it level.
SHSU
When I replaced the bow supports and cover plate I beefed up the supports with a solid piece of ply. It still has a little bow to it, so I needed to add some shims to level the TM a bit, as well as allow clearance for inserting/removing the arm for the TM quick release bracket. The spacers were a combination of stainless fender washers and rubber fender washers. The bracket is through-bolted with washers and loc-nuts. Much easier mounting just the bracket rather than the entire motor, but a lot of trial and error to get the right shim/adjustments.
redneck joe
if that 90 is running, and you are wanting to free up garage space, i might drive up for that.
airshot
Thanks for the pics...brought back lots if fond memories. I had one if those back in the 80's. Great boat...ours had a 70 hp and would do 35 mph.
Had lots of good times in that boat....
DWbaseball
This one is finishing up looking really nice!! Been watching for awhile and glad to see it all coming together. I really like that later era low profile splash well.
MNhunter1
Starcraft on the water! Went to a local electric only lake over the weekend to test out the trolling motor and electronics. Towed well, launched well, everything worked, and no water in the bilge after multiple hours on the water over a two day period. Most importantly though...the kids got on some bucket mouths!
redneck joe
so awesome.
Might i respectfully suggest you pick a couple three of those and (in case you were not aware) put them on this thread>
