jimmbo
- Joined
- May 24, 2004
- 14,561
if the ignition system is capable of jumping a Spark 3/8" I would be very hard pressed to say the Coils are bad. However, if the wires have a weak spot in the insulation, there as possibility that the wires when relocated as they are when connected to the installed plugs, are able to arc to ground. I know it is a slim chance, but I have seen difficult to trace voltage bleeds in the past. Dirt on the plug ceramic insulators can create an electrical path to ground. Electricity has only one thing on its mind, complete the circuit to ground, and it doesn't care how it gets there
