Mercury 850 85hp. Good engine or stay away?
Attól függ, hogy a gépet gondozták-e, vagy csak a tulajdonában volt, a kettő nem ugyanaz...
It depends on whether the machine was properly maintained or simply owned—the two are not the same...
Bman2895
If you left the rectifier (serves as voltage regulator on that motor) unconnected to the battery but connected to the stator, it will blow.
So I replaced that wire however I didn't wire it into the harness constant 12. I ran the wire from the back of the regulator to the big lead coming into the starter solenoid. That should be all right ?
I am not sure I understand your post. Generally, if the rectifier is connected to the 2 stator wires, but not ground or +12VDC, it will blow.
Bman2895
So I reconnected the positive wire for the rectifier. Normally it joins into the engine harness. Into the red wire that feeds the trigger box. A constant 12v. Instead of connecting it to the harness there like the factory was. I ran the 12v from the rectifier to the stud on the starter solenoid where the 12v battery cable comes in. So it's still connected to a 12v constant wire.
Gee, that should work. You might test the diode with an ohmmeter, to make sure it is still good. If not, Amazon likely has a 15 to 25A generic full wave rectifier that will replace it for small $$. It makes no sense to buy an inferior OEM rectifier for large $$.
