Mercury 850 85hp. Good engine or stay away?
Honorary Supreme Mariner
Those shocks prevent engine from slamming into the transom AFTER hitting a submerged object at speed.
Texasmark
Those shocks on the motor? Are they designed to help lift the motor or just to lower it slower? Cause they dont seem to do much of anything either way.
Back in the days of the cross flow 4 and then 6 cylinder Mercs, at Lake X in Florida (Mercury's proving ground) boats would undergo destructive testing (being powered with production Merc. engines) to weed out the weak points of the engine. They named the lake X because giving out its real name would/could benefit competition in seeing the results of the testing....(opinion).
One of the tasks was to run over semi submerged logs. Mercury's streamed line lower unit, unlike OMC's gear box protrusion, had no problem running over the logs. The problem was that impact at high speed caused the LU to rise up (very high) and with the prop still turning at WOT throttle, came slamming down against the transom bracket with great force and serious damage to the engine and boat were just an accident waiting to happen.....I have seen pictures (side views) of this testing before, during, and after the impact......may have seen a video.....hard to remember exactly.
The shocks mounted outboard of the engine on the midsection and clamp bracket reduced the upward and downward travel basically reducing the effect of this from happening. And, as it turned out, when Merc. first decided to add PTT to its engines, these shock mounting points easily became the mounting points for the first series of Merc. PTT cylinders.....my 850, currently being discussed in this forum had such an arrangement.
When Merc. upgraded its midsection/lower unit to today's configuration, the cylinders were redesigned and mounted between the ears on the clamp bracket and the trim cylinder was just a push rod, allowing the MS/LU to raise easily during impact with just the two shocks having to release pressure.
Chris1956
Actually, The PTT cylinders only attached to the orig. shock lower mounts. The shock upper mount bolts were used to bolt on a PTT cylinder bracket. You can see it in the pictures.
The PTT cylinders upper mounts were at the top of the transom, whereas the shocks upper mount was about 1/2 way up the transom bracket.
jimmbo
I had a 78, replaced it with an 84. Hated the Fecal Matter Brown, so I found a cowl from a 1971 for it
Now that the Thread has been sent off on a Tangent... Back to the Regularly Scheduled Thread
Bman2895
Well the crappy wiring finally bit me. All I did before it was put some liquid electrical tape on the stuff and let it go. Took it out today and twice it just died on me and wouldn't restart. Both times it was spark. Floated it back on the trailer and brought it home. I put this off thinking I was going to open some can of worms, but it didn't take me 30-45 minutes to pull the harness off and just splice back and replace the whole engine harness.
Spark is fixed. I replaced the wiring to the choke but it still doesn't work from the control box. I know it CAN work as I jumped the wire to positive then the electric choke works. The stator wires are still junk and I didn't touch them as of now. I also didn't wire the output of the voltage regulator back into the harness cuz I highly doubt that was doing anything anyway.
Chris1956
If you left the rectifier (serves as voltage regulator on that motor) unconnected to the battery but connected to the stator, it will blow.
Bman2895
Gotcha. So disconnect the stator. I haven't ran it yet since repairing the wiring.
I really don't feel like pulling the fly wheel to get at that stator, but I might try pulling the wires back and just putting some heat shrink on them and replacing that charge wire back into the harness. See if it works.
Chris1956
You can remove the 8 5/16" bolts around the flywheel nut and the flex plate will come off. The stator will also come off.
Mark the position of the flywheel and flexplate to make reassembly easier. Use blue Loctite on the 5/16" bolts and the distributor pully bolt when reassembling.
