Texasmark
- Joined
- Dec 20, 2005
- 15,046
Er ah.....my Mercury manual says that if the Stator yellow wires aren't connected to a circuit....rectifier and load, or rectifier/regulator, the Stator is damaged. My guess is that the voltage rises to a very high voltage (with no load) and you have an arc-over in the Stator.....we addressed that in an answer above.like Boscoe99 said
the yellow wires need to be disconnected from the RR when testing for AC to see if it is putting any AC voltage
