Boats from work.
alldodge
Don't know about you but under the house hear is much cooler than outside. Last few days I've been doing square bale work, and it's in the 90s
MikeSchinlaub
Ensign
Ok, I'm a bit late on updates, but here's the situation. The Sea Doo is gelled, but we can't get paint from any of our usual methods. So the boss is taking the chunk that I cut out to another place to try to get some.
While I wait for that, I have another one with pretty much the same thing.
MikeSchinlaub
Ensign
I had to put this bit of scrap aluminum behind the break and screw it to even out the break for a mold.
This one was tighter to get in. So I used the first 4 screws to hold it back while I pushed plexus in all around.
That's epoxied in place. If I had time, I would've taken a pic of all the excess oozed out. I also ground it today, but forgot to get that.
redneck joe
now is your chance. I can see a green inchworm smiling at me from that hull. Wearing red sneakers.
redneck joe
best sales people in my experience who worked for me over the years are people that do the work, know the work, believe in the work. It then is not selling, it is showing the obvious.
MikeSchinlaub
Ensign
Glassed yesterday. Today I'm starting with just sanding and buffing the blend on the seadoo.
MikeSchinlaub
Ensign
Sprayed, sanded, and started buffing today. I had trouble getting the shape right, so I black gelled my bodywork yesterday and blocked it out some more.
MikeSchinlaub
Ensign
Just a little spot in on a 2027 Caymas.
Have to give credit to Beave here. When I got to the flake, it just wouldn't come out of the gun. I got a few seconds of good spray, and managed to mostly cover the spot. He managed to get enough out to finish blending it.
I think it was because I didn't have enough fluids for the flake. Normally, I mix the clear how I want it, then add the flake. This time though, they didn't send much flake, so I poured it in a cup and added clear and acetone to it. I thought it was good, but there must have been clumps on the bottom that I didn't get mixed in well. It turned out well though.
Bonus, check out what the leftover clear did to the cup. Yeah, I way overestimated how much I would need.
MikeSchinlaub
Ensign
We FINALLY sprayed the hull of that Caravelle that I posted about back when I first joined this forum.
This was my first time using the pressure pot gun. I can see why Beave used to go through a pair of boots every week when he was spraying molds way back when.
