PCV Valve
camboat
I’m adding a 1” spacer under my carburetor with a vacuum port. The port will be capped off for now. I have installed a catch can to capture the oil mist to keep the carb clean.
Should I add a pcv valve to this setup? Is there any benefit to have a pcv valve?
Every once in a while I get a weird reading on the oil dip stick. It reads low.
Thanks for help!
Grub54891
Under the carb won’t make the carb dirty. Neither will hooking up to the flame arrester. I would hope you are using a true marine carb! I’ve seen a few that were not marine carbs and our shop won’t work on any unless they change the carb, or have us do it.
youre overthinking it.
oil mist and aerosol from the vents is supposed to be routed to the carb via tubing. this is done to keep explosive gases from building in the bilge.
if you have a lot of oil mist coming from the motor, you may want to do a leakdown test. your motor may be tired, or you may simply need valve seals
the weird reading on your dipstick is most likely the angle the boat is sitting at.
camboat
The carb is a new Edelbrock 1409. The motor has about a 100 hours on it. The oily mist is making the carb dirty, that’s why I added a catch can. The motor runs great!
Thanks
camboat
Will today I pulled the carb off and cleaned it up. It was a bit oily from the oil mist. I added the 1” spacer to help with the heat and it has a vacuum port if I need to add a PCV valve. Attached is a video I took with a paper towel over the oil fill. As you can see there isn’t much blow by. This was at 700 rpm to 3800 no load. Nothing coming out of the dipstick. No smoke out of the exhaust.
I’m puzzled by the loss of oil on different days of boating. As you can see in the video it runs great. I just winterize it, so I have wait until spring to see what the oil catch can catches.
Thanks for any help!
  • IMG_8388.mov
  • IMG_8389.mov
