Water in exhaust manifolds
Lou C
I see some light scuffing on the cyl wall in the 1st pic, definitely a valve seal leak in one cyl, also the motor was rebuilt at some point because I see a piston stamped .030”.
Looks like some very light corrosion in one of the pix as well. Nothing too bad though….
Holy detonation pock marks batman.
Agree with Lou. Someone has been in the motor before
chartersj
Yeah I bought the boat with roughly 100 hours on a rebuild. I’ve since put another 100 on it. To me it didn’t look like water had been running though it too much if any. A week before I initially pulled the risers I did leave the boat in salt water for a week. Which I normally don’t do. I would think if salt had been laying around I would have seen more traces of rust
Lou C
If you blow up the pix of the top of the pistons you can see pock marks, that is what I think Scott is referring to. Can be Caused by lean fuel mix, fuel octane too low, timing too advanced and prop too large in pitch. If the engine doesn’t reach its specified wide open throttle RPM you can get detonation because the engine labors every time the boat gets up on plane. What your max WOT RPM? Should be about 4400-4600 rpm and actually higher is better as long as it’s under 5,000 rpm. Check your timing make sure it’s right. I use at least 89 octane gas no matter what the manufacturer says about using regular. That’s a big heavy boat for a 5.7. What size prop is on it now?
Lou C
I am going to post up an old pic of my 4.3 when I had it apart about 10 years ago. The pistons show carbon build up (the Q-Jet was running too rich then for sure) and on the center piston you can see the lack of pock marks, this engine at that point probably had at least 1500 hrs on it, had one bad overheat and the blown head gaskets a few years later, but it doesn't seem to show detonation damage, at least from what I could see. The liquid in the cyls is fogging oil to keep the cyls from rusting. Block still needed some cleaning in that pic!
Maybe the water in your manifolds was a blessing in disguise, if not looking for things you'd probably never had noticed that.
I would: consider getting the injectors for your TBI system cleaned, make sure fuel pressure is what it should be
check timing
see what your WOT max RPM is, if too low you have to start looking for causes, sometimes it's as simple as the boat ran OK with the wrong prop on it and no one ever thought to check, on mine it had a 14.5x19 which was too much pitch, it needed a 15x17 given the little 4.3 and the weight of the boat (a lot for a 20')
Another cause which could be easy to miss, is the ratio of the outdrive, each engine has it own specific outdrive gear ratio like a ring and pinion on a tow vehicle. If the outdrive was replaced, someone could have used one with too tall of a gear ratio, so that can be a cause too.
use at least mid range fuel, in a marine engine you really can't hear pinging or detonation but it will eventually burn valves and can shorten engine life.
chartersj
check timing
Wow you’ve been very helpful on here.
Very much appreciated.
The 5.7 was the smaller engine for this boat for sure, but with the bravo 3 drive and 22 pitch props it doesn’t struggle to get on plane. As far as top end rpm. I think I’m around 4500. But I’d have to double check that, probably next summer as it’s getting cold here in Canada. I do have a fuel pressure kit to check that, and I agreed about getting the fuel injector cleaned over the winter.
I have my new gaskets so I’m going to put the exhaust back on, swap the plugs around, and keep the throttle up a little more to see if that helps with the water in the exhaust. I looked down through the y pipe for broken off exhaust flappers that might have failed at one point but didn’t see anything.
I’d love to think I could see 1500 hours on this one lol
As far as I know it’s the original drive to the boat, that was re-sealed same time the engine was rebuilt.
chartersj
I have plugs in the top of my risers big enough for my borescope to fit in as well
Lou C
seeing as how you're in fresh water now, that exhaust should last the life of boat, hopefully you can stop any leaks.
the one thing we still don't know, is if the water was caused by condensation or a leak, but if you can check em as I did, if you see a bit of water after idling on the water hose but not when the boat was run fast enough to get the exhaust up to temp, then I'd say it was condensation. If you still get water after running it enough to get it hot, then it's a leak.
I think 1500 hrs is entirely possible, as long as maintenance is kept up and you use good fuel, and monitor things like max RPM (4500 sounds like it's high enough) and timing. Marine engines especially inboards are under loads that you do not see in automotive applications, where you have a multispeed transmission and aren't pushing a wall of water out of the way to get the boat up on plane.
chartersj
So I swapped the plugs around, filed the mating surfaces down on the manifolds and risers, and run it again on the hose. First I left the hoses to both exhaust manifolds off so no water was going through the exhaust, and let it run only for 30 seconds. Put my borescope in through a plug hole in the top of each riser, and no water was in the bottom. Pulled the spark plugs, and all of them looked exactly the same with a nice dry dark color.
Then I put the water hoses from the thermostat back on each riser and run it again, at first just at idle until I just seen the temp coming up on the gauges, so only a couple minutes, and noticed a couple water droplets laying it the bottom after that.
At that point I started it up and bumped the idle up to 1200 rpm and let it run for another minute, then checked again. Bone dry in the exhaust.
So then, I started it up, bumped the idle up to 1200 and let it warm up the rest of the way to operating temp, 160 degrees, and checked again,,, puddles of water only in the middle two ports on both sides, looks like water droplets coming down from ABOVE the riser gaskets. Also it’s dry right out of each port in the heads until it turns 90 degrees up.
So am I seeing reversion, or cracked elbows that leak once up to operating temp, or both?
I pulled the risers off again afterwards and I really appears that they are sealed fine, but I am using Amazon gaskets.
chartersj
The boat is now winterized for the season
Lou C
You might have rotted elbows since the leaks seem to be coming from above the gasket. Not a big deal to replace both of them, glad to see you're still at it, you'll get to the bottom of it.
Having said that, are the manifolds as old as the elbows?
Isn't it amazing what these cameras can show?
I saw Eric O on South Main Auto You Tube find a leaking head gasket on a Honda CRV the same way.
Scott06
agreed this is an easy way to loose an engine
Lou C
this test will work on manifolds, but I have not tried it on elbows
remove manifold
prop it up level
carefully fill with acetone (careful, very flammable)
look for leaks in the ports that line up with the exhaust ports in the cyl head.
acetone has less surface tension than water, so it finds leaks that won't show just by filling with water.
maybe it could work with an elbow if you turn it upside down?
chartersj
PS your plugs still look overly rich
should be light tan/grey
Not sure on the age of them. I’m thinking I’ll change the risers first in the spring and see how it is after that before I do manifolds too.
I filled the manifolds with water but not acetone so I will try that too.
And yeah the plugs do seem like it’s running rich. I still plan to have the injectors cleaned and tested over the winter.
The camera is a game changer. Been using it a fair bit. Friend of mine wanted me to see why the engine in his four wheeler wouldn’t start. Put it in the spark plug hole and this is what I see,,,,
tpenfield
Reversion would be indicative of a camshaft that has a moderate-to-high level of valve overlap. So, if it is the stock cam in the engine, probably not reversion.
Scott06
That will buff out.… years ago my friend who is of extremely limited mechanical ability says I hit a rock with my mower now it won’t start… I’m thinking the shear key way on flywheel, easy fix. Key was bent a tad but Intact. Take spark plug out and I can push the piston with a screw driver…
back to the exhaust, yes could be riser but if you are gonna keep it just change them. You see water coming back. If risers are gone are manifolds far behind? Yes easier for me to say than you to spend but it’s not a cheap hobby, and this is a real easy way to loose a engine
SeanTedd
Before winterizing this year I decided to pull the risers on my 5.7 efi open cooling, to check the gaskets, and found a little water in the bottom of both exhaust manifolds. I boat in salt water, flush it on the hose after every use, and the water in the exhaust manifolds was fresh water.
The gaskets appeared decent, but changed them out and put it back all back together with new spark plugs. Ran it on the hose for 15 minutes. I then pulled the risers again to have a look, and there is water in both sides again.
I also pulled the plugs, no evidence of water in the cylinders, but a couple of the plugs were much darker then the others.
And the engine oil is clean, starts easily and seems to run great.
Just wondering where else I should be looking at for water intrusion?
I’d pressure-test the exhaust manifolds and risers, and check for cracks or corrosion. Since both sides have water, I’d also verify the flushing procedure and exhaust shutter condition before running it any further.
