1999 Johnson 115 Carb Rebuild - Seat Washer?
Captain Jeff
Hi, I am rebuilding the four plastic carbs on my ‘99 Johnson 115. The OEM rebuild kit has a small bag that contains the new needle, needle clip, seat and a translucent plastic washer that appears to belong to the seat. My carbs did not have this washer and the diagrams I found do not have it listed. It fits well under the new brass seat.
My question is: am I supposed to use this new washer? Or do the new seats just screw into the plastic carb body without using it? Maybe this is an updated design? Please see the pics. Thank you!
Mc Tool
Id say at a wild guess the same kit does the metal carb bodies and would need the washer/seal
Check float bowls.-----They are often warped.-----Do not use the washer on the seat.----Why did you decide to " rebuild " these carburetors?-----Running issues?
Captain Jeff
I am rebuilding because all the bowls were warped and leaking like you said. Also it is smoking more than normal so I rebuilt the VRO. And one spark plug was a bit fouled so I suspected a possible carb issue there
Post the actual compression values here.----Are you installing new float bowls?
