Removing rocker box / valve cover Merc 3.0l in Bayliner
Simoniz
So then next stage in tracking down the annoying oil leak on my boat.
I removed the spark plugs for winterisation and the well in the head for No4 plug had oil pooled in it, which I suspect has come from the valve cover / rocker box.
This boat was used in salt water, and Ive already replaced the timing gear cover and pushrod cover due to rust, but now suspect that the rocker cover might be rusted through as well.
Ive got a second hand cover in great condition, but now wondering if theres room to remove the rocker cover from the 3.0l engine when fitted to the Bayliner 175 (year 2000).
I can't look at the boat easily since it's covered up for the winter, and removing the cover involves miles of string...
Anyone know if theres clearance to lift the rocker cover off the top of the engine, or will it foul the structure of the boat?
also pull the motor and then pull the oil pan.
the area behind the damper never got painted and was raw steel. that is usually where the oil pan rusts thru.
valve covers generally do not rust thru. but if someone was in there before, they could have damaged the gasket.
Scott06
I would think slow your roll get a few cans of brake cleaner from top down clean off any oil. Get a UV dye and light put it in the oil and run it so you can see where the leak is coming from.
As Scott mentions they do rust out behind the dampner as they dont get paint, so you may have to pull the engine and drop the pan and replace it and or the timing cover if perforated.
While removing the engine sound difficult its not and you can run it on the ground after doing the work to see if it is fixed.
As for removing the valve cover in boat - yes that is most likely easily done but with out a picture its hard to tell from the key board.
Simoniz
Cheers all.
Well, as mentioned, the oil is definitely coming from the top of the engine, so cant be a sump leak. When I replaced the timing cover years ago, I gave the sump a good spray with Waxoyl, and usually either give it a rub over with some of the used engine oil when I do an oil change, or re Waxoyl it periodically.
However, Ive got a boroscope on order so Ill have a look a the back of the oil pan when I get that - easier than removing the engine, ha ha.
Yes I appreciate that its difficult to tell whether I can get the valve cover off, but I expect I can. It would be a poor installation that required engine removal to set valve clearances - but poor installations do exist. It makes little difference at the moment anyway; come the spring, there is either enough room or there isnt.
