Fuel pump issue
The Worminator
I got my engine all back together and now I have a fuel supply problem. Even with a new fuel pump, I have to constantly squeeze the ball to maintain fuel supply. Is this a carb issue? I replaced the exhaust skirt gasket and It runs beautifully otherwise. Those obviously shrink when they dry out with age.
Check the hose for leaks.----Check pick up tube INSIDE the fuel tank for leaks.-----Fuel pump is drive by crankcase pressure pulses.----Check for issues there.-----Picked up 5 of these 9.5 HP motors in the last 2 weeks for parts / repair.----Great , light weight motors.
The Worminator
I’m at a loss. When I started today, the primer ball would get rock solid, and it would run for about 3 minutes and then air would start appearing between the fuel pump and carb and it dies. Then the ball wouldn’t get hard anymore, so I got a new one, and it still would not get hard priming. I also thread taped the connector at the fuel tank. Now it won’t even push fuel to the carb, and there is no fuel leaking anywhere. If I were to place the supply line directly in a fuel container, should it run??? I’m just trying to rule out a bad tank. I had no issue with the tank before. I also am wondering about the pulses that run the fuel pump.
Crosbyman
which pump are u using the small square OMC of the bigger one .
try lifting the properly venting fuel tank above the engine and get it running....see if stays running by gravity feed of fuel to the carb via the fuel pump check valves...
if it runs ok lower the fuel tank below the power head ( boat floor !!! not a shop 2-3 feet below the pH. these small pumps can only pull UP so many inches.
report back
The Worminator
I tried both, they both do the same thing. I did place the tank in the boat, and no luck. I just don’t want to spend the money on a new fuel tank and have the same issue. Lol
Replaced o-rings in fuel line connecters?====Does spark jump a gap of 5/16" on both leads ?----Post actual compression values here.
Berdink
Have you tried using a different hose and squeeze bulb?
Lou C
Wonder if you have an air leak in the fuel line from the tank to the primer bulb…or a restriction in the fuel pick up tube…
The Worminator
I ended up figuring out the brand new Chinese fuel pump was the issue. It worked for about 10 minutes! Old one back on and she runs like a champ.
