1993 Crownline 196 BR fuel tank access port gasket
keviwe
I just bought a 1993 Crownline 196 BR. It's been stored for years so I plan to remove the fuel tank access cover to siphon out all gas. I will replace the access cover gasket. This is a 40 gallon tank.
Does anyone know wat company made this gas tank so I can order the correct access cover GASKET
keviwe
Unfortunately, I store this boat in another state so I can't check the label on the tank, until I get out there to start working on it. I'll have a week to get it running and no time to wait for on-line parts to be delivered. I might have to just buy (from the link you sent) and hope for the best.
tpenfield
You can also siphon (pump actually) from the main fuel line . . . no need to remove the sender, unless you want some visual of the tank internals.
keviwe
Here is a pic of my Crownline gas tank access port. 6 screw holes and OD is 12-1/2"
Any idea where I can find a replacement gasket. 1993 CrownLine 196BR with 40 gallon tank
dingbat
They're readily available but vary by manufacturer.
You'll need to pull the cover to get the mfg. off the unit.
I replaced all eight of my access port o-rings due to age.
Ordered the correct size rings from McMaster Carr.
Saved quite a bit of $$$ over purchasing individually from the mfg.
keviwe
Now I'm wondering if this is a pop-up lid that exposes the sending unit. I need to open the tank to siphon all the 15 year old fuel out
keviwe
I guess I'm now looking for a sending unit gasket. I'm wondering is they are pretty standard. It will be difficult for me to get another pic since the boat is stored 1200 miles away
dingbat
Yes, its a pop lid...you can see the "pry" location on the right side
5 holes sending unit gaskets are all pretty much the same.
All you want on Amazon
That $15 inspection port has a simple o-ring to hold the cover
Under that cover is the sending unit and the anti siphon valve
