What Can You Tell From This Picture.?
Lou C
If you have to do an engine rebuild, you can convert it to Vortec heads, 4bbl intake and add an Edelbrock 1409. Money yes but probably worth it if the old heads have to be redone anyway.
Mark R.
That would certainly be a definite consideration.
Any idea of a ballpark cost these days for those three ticket items.?
I'm sure there'll be other items (brackets, lines, etc.), but I'm fine with that.
What is the consensus on the HP increase (pre-Vortec 2bl vs. Vortec 4bl).?
Keep the V-belt accessories, or would those need to be changed also.?
Lou C
I'd keep the V-belts, serp belts can have troubles of their own...
An intake and a carb, is going to be at least $1,100--$1,300 depending on if you buy new or used
Cyl heads are about the same price for pre vortec or vortec if you need remans.
If the old heads are in good shape, you can save money sticking with them
And, you could add a 4bbl cast iron intake and a 4bb carb for a lot less than a full change-over.
If your original heads definitely need to be replaced, the full change over makes sense.
4bbl carb may add 25-30 hp on the top end
Vortec heads may add another 25 hp to that
Scott06
Thank you guys, for all your feedback on the engine picture.
It seems unanimous now that this 5.7 is a pre-Vortec with a 2 barrel carb.
I was prepared to take a chance and drive out to thoroughly checkout the boat.
But I was really hoping it was a Vortec with a 4 barrel that I could enjoy rebuilding.
The rest of the boat looks pretty darn nice, especially the original upholstery.
If I had encountered soft floors or transom I would have passed on it anyway.
You are right to ,focus on the floors transom and stringers. The engine is easy if the structure is ok.
crazy charlie
The easiest way to tell is that a 5.0XL and a 5.7 XL are 4 bbl carbs, a 5.0 and 5.7 are 2 bbl. The XL is the difference assuming it is the original flame arrestor cover, thats where it usually spells it out. Charlie
Mark R.
Did you mean to say "LX"..?
I don't think I've never seen "XL"...
Mark R.
of course he meant LX , XL is his shirt size...
OK. So is the LX designation definitive for the 5.7 and 5.0 V8's..?
In other words, does it for sure indicate that they're 4 barrel carbs.?
If so, that's good to know, but I don't think that's true for the V6's.
We have a Merc 4.3 LX Gen+ in our little 1996 Sea Ray 175 BR XL.
And it's a Vortec V6 engine with a 2 barrel carburetor (0F803561)...
Lou C
Just remove the dang cover lol. Weber 4 bbl had fuel line on the left side of carb goes all the way back. Mercarb is same as a Rochester 2bbl.
Mark R.
Well, of course. That's always conclusive, and naturally what I do if I'm there.
But we're talking about when looking at boat ads, and deciphering pictures...
Mark R.
Here is another possible candidate. This one is in a 1998 180 runabout.
Would you guys agree this one appears to be a Vortec 5.0 with a 2 barrel carb.?
I would most likely pursue uprading it to a 4 barrel manifold and carburetor.
But even with a 2 barrel, it should move along pretty well in a little 18 footer...
Lou C
Yep that's the 2bbl Mercarb/Rochester carb.
In an 18 foot boat it might be just fine.
Scott06
Yes that should be fine if propped correctly. 220 hp As is. Michigan motors can set you up with an edelbrock 1409 and they sell a reasonably affordable cast iron 4 bbl intake. You can use this throttle bracket
https://www.marineengine.com/newparts/part_details.php?pnum=MER805359T for a clean oem install. Throttle cable will bolt up as well as the slave solenoid and circuit breaker which is usually on the throttle bracket on back of the carb.
Mark R.
Thank you, Scott.!
That's great information.!
My 2002 searay 190 has a 5.0 2-barrel. It would do just shy of 50mph. An intake and 4-barrel would get a bit more
Mark R.
Yes. I would hope for a noticeable change in the horsepower.
And increasing top speed with more HP would require a prop change.
(since the maximum RPM of the engine at WOT should stay the same).
So is there ever a need to also change the gear ratio of the outdrive.?
I would expect (and hope) not. Just a slightly higher pitch on the prop.?
The 4-barrel will add about 15-20 HP
The vortec heads already took the motor from 190hp to 220
Scott06
I thought general consensus here is 10-15 hp for 1 mph of top end improvement, so calibrate your expectations as it takes a lot of $ to go faster in a boat.
Depending on where you are in terms of WOT rpm range you may need a prop change to go up in pitch. Most of the time its seems like people are over pitched somewhat (WOT RPMS on the low side) so try it out and see. Best advice I would give is to prop to the upper end of the rom range (4800) not that you have to run at 4800, but if the boat can nip the rev limiter the throttle response and performance will be nice through out the rpm range. The biggest thing I got from a 4bbl was much improved mid range punch and throttle response.
on the drive yes there are time you may need to change the ratio. My current boat is a 21 ft Sea Ray 200 sport. that I bought with a known cracked block (4.3/ 190hp/ 1.84 ratio drive). same boat was offered with 4.3 mpi (220 hp, 1.62 drive), 5.0 2bbl/1.62 drive, 5.0 MPI 1.62 drive.
I debated going back in with a 5.7 but thought( mistakenly) it would be too much power, so I put a 5.0 with 4 bbl carb and theroteically 260 hp. Boat only had 37 hours so I hated to swap the drive. Tried it out and was way under propped with the original ss 19". Went up to revolution 4 21" pitch and can just tap the revlimiter lightly loaded. So it seemed to me that the drive ratios help keep props within the normal 17"-21" range.
If I had done a 5.7 and a 23" pitch didnt work then defintely would have to swap the drive ratio or upper. Boat works great for the last 10 years but knowing what I know now I would have done the 5.7 and a 1.47 drive .
