inboard engine in sterndrive boat
Cdn20valve
Is it possible to install 2008 merc 6.2 horizon MIE mpi into a sterndrive (bravo) boat? I got a potential great deal on twin 6.2s. but they are inboards. they come with the trannies. which i wont need.
How involved to swap them to a sterndrive boat? what parts would i need.
Just looking at it, ill need a power steering pump, and a new serp belt. some hoses i think
I'll be removing 1996 5.7 efi tbis.
thanks.
ECM is slightly different, everything aft of the flywheel is different,
Other than that, the block and heads don't know what they are turning
Bt Doctur
the 5.7 and 6.2 are from the same family,need the rear housing,coupler
and ecm reflash for the bravo drive
alldodge
My opinion
Both the MCM and MIE have a In Gear switch they are in different locations. Would need a motor serial number to drill down further. The 6.2 was used with Alpha, Bravo, Inboard, Mechanical and Digital shift. Going from Mechanical shift (555 ECM) to Digital (555 PCM) can make a difference
For the most part I'm thinking it could be done, but would like @muc input
Your not going to get it reflashed but can replace but that's costly
Scott06
what's involved in getting a reflash? seems complicated
It can be done by a dealer who will work with you (of course depends on the exact ecm). I looked at the used MPI set up for bravo to replace my alpha set up engine. Dealer selling it said he could reflash it. Take the serials and call a dealer.
Muc will know as well.
Mechanically inboards us a different flywheel, flywheel cover and starter as starter is top mounted vs under block mount on stern drive. They should swap over from your old engines.
muc
"Retired" Association of Marine Technicians...
No he doesn't.
If a customer walked in with this question, I would call Merc tech support.
My guess is that the 6.2 ECM might work OK with a Bravo. Inboards have shift assist strategy in the calibration because inboards props usually have more bite on the water. So there might be some engine flare when shifting a Bravo -- not sure if that might cause issues with the cone clutch. There also might be some issues with the inboard fuel and ignition maps. Inboards don't trim out.
Probably won't be able to "reflash" the ECM. The computer diagnostic system (G3) isn't really set up to do this. It needs to see what the current program loaded is and only looks for more current calibrations. It might be possible with help from tech support, but why would Merc want to do this for free? It's not in their best interest.
I could see this needing about $2500-$3500 per engine in parts, depending where you source them. Plus another $2700 per engine if you need new ECMs.
You will need to do a bunch of research, this might not be a easy swap.
Quick possible list:
starter, flywheel cover, coupler, maybe flywheel or move ring gear, shift bracket, front motor mounts, cooling hoses and the P/S pump might need the alternator moved, so there might be new mounting brackets.
Maybe you can reuse some of this stuff from your old engines?
BUT, if you can do it on the cheap ---- a pair of 6.2s might really turn your hull on!
