sumocomputers
Thread starter- Joined
- Feb 23, 2015
- 123
1989 Johnson 70 Warning Horn Seems Faulty - Do I need it under my Circumstances?
I have a 1989 Johnson 70, which fails any warning horn tests of grounding the 3 tan wires with ignition on (VRO, oil tank, engine temp sensor tan wires). This leads me to believe the buzzer itself is faulty.
I understand that the warning horn alerts for low oil, no oil, and engine over-temp. The buzzers are not cheap at $65-85 for such a little thing, and the control box looks a little scary to open up.
Also, it seems the S.L.O.W system would slow the RPMs if it gets above 203F (assuming the S.L.O.W system is working!).
Since I am very likely going to disable the VRO2 system in the next few days, and I have just installed a new Sierra Temp gauge and sending unit, how important is to test and likely replace the warning buzzer?
And if you recommend I should get in there to test the buzzer, could I just apply 12V directly and verify it that way? The official service manual doesn't really address accessing or testing the buzzer, so just trying to get some direction on the best way to go.
Thanks,
Chris
Thanks,
Chris
