enginesilo
Thread starter- Joined
- Jun 9, 2008
- 355
My engine has always seemed to run hot on the gauge (175 F degrees) with no other symptoms or issues, but this year it has me worried as it seems to have climbed to around 190 degrees while I was getting things ready for spring on the hose.
I shot the engine in a few spots with an IR thermometer and read around 190+ degrees on the block below the exhaust manifold, and the manifold and riser were at least 170 degrees. However, the thermostat housing never seems to read very high, maybe 135 or so. It also seems like the boat didn't start spitting out water from the back for a good while, and then it still seemed minimal.
Last year I thought it could have been the impeller, so I dropped the lower unit on the drive and replaced it. The old one was still in perfect shape so no parts sheared off to get stuck or anything like that.
Today I decided to go ahead and try to change the thermostat (160 Degree) incase that was a possible easy fix, it seemed to run cooler for a little while, but then it was right back to around 185+ degrees.
A bunch of people told me I should be able to hold my hand on the riser without it feeling too hot, my riser is definitely too hot to keep your hand on for more than a second or two tops.
Engine is a 2005 Mercruiser 3.0L with a Serial starting with 0W0, here is a link to my engine parts catalog:
http://www.marinepartsplus.com/catalog/mercruiser/serial/3.0L_GM_181_I-L4/804862+99
Has under 100 hours on the engine. It is a salt water boat, and I've had it in the water for the past 4+ years or so.
Engine starts right up, idles fine, and seems fine other than the temperature is too high.
Can anyone out there help me think of what the check next?
-Possibility a tube is clogged? If so, which and where, and how do I get to it?
-Is there another secondary pump of some sort, like a circulating pump or something on the engine that could also need changing? Or is that only the larger engines?
-Any way to detach the tube that comes in the transom from the outdrive where it connects to the engine to see if water is gushing it as it should?
-If the thermostat housing seems cool but the riser and exhaust manifold are hot, could it be a clog in the manifold?
-I'd hate to get back to the impeller since I just changed it, but could there be anything there to look at again?
All feedback appreciated!
