Update. You guys were right... twice the machinist didnt bore the full length of the sleeve! Got it worked out. Needless to say, I won’t be back.
Anyway, got the main block back together. New pistons (.02 over and rings, upper and lower bearings, crank back in and sealed with gel seal 2. Crank turning smoothly
. Now re-attaching external/ancillary parts. Finally making some progress.
Now a few questions moving forward....
1. Any tips/tricks/pitfalls to be aware of at this point.
2. Thoughts on upsizing jets in the carbs? Is that necessary? What size would be correct? 150sltcem
3. I assume a link and sync and timing need checked before any running above idle revs?
4. Oil pump disconnected. Double oil mix in fuel for the first few tanks??
thanks
