‘96 mercruiser power steering leak,
brunolund
hello. I have a 1996 mercruiser 5.7 2bbl in my lund. I have a leak in my power steering system that i have been unable to locate so far. I originally assumed it was the cooler, but i removed it and pressurized it (PS side) with 25psi of air, and submerged it under water for an hour. there was no leak detected. the hoses look fine. that leaves me with the pump, which shows no signs of leaking, or the ram assembly on the transom. this is extremely hard to get a good look at, although i will remove some panels to get better access. my question is are these rebuild able? if so, what numbers do i need to get the correct seals? when i fill the PS, it works fine, just leaks out somewhat quickly, like 5-10 hours or so, run time.
brunolund
i do have some PS fluid in the bilge now, that i didn’t see previously, so the leak is there somewhere!!
Take a white or light colored rag and feel along the HP hose to see where the fluid shows up
You can wipe the rag over the unit to see if any oil shows up
brunolund
will try that shortly, gonna give it a good clean too so can see new oil.
rebuild kits for the pump are about $14 should you need it
usually its the return hose that leaks
brunolund
anybody have any idea where i could find a manual or a good diagram for disssassembly of the steering ram?
brunolund
i’m hoping it’s just a hose, but they look good for now. can’t test till my exhaust gaskets get here, as i had to pull a manifold off to get to the cooler.
Don't know of any showing how to disassemble the unit. My guess is it's not the unit, it's somewhere else. I bought one of them a long time ago thinking the same thing. By the time it came in I found it was the return line. The unit still sits on my shelf
Most all of the Merc engine manuals have a power steering section
