Cheers Guys,
Getting some prices now on the gear needed, yes it will be new piston and rings through out, this does knock the price up but is the best way forward. Got 2 prices already with a big difference, could be sierra piston and ring set yet but still to decide after a few more prices come in, as long as there all the same I'm not too fazed which one's unless there's some to stay away from ?.
Finally got the motor off today, I've had the leg off not to long ago and should have dropped that first, seems the studs coming through the front were corroded making the job hard, few photo's below after lugging to the car ready for pull down new years day at the work shop!
I want to go ahead and purchase 0.020" OS now so we have something to machine too, unless I have the new pistons how do we give them the tolerances to machine too ?.
Also, the head! mine looks Phuked but may have to be cleaned up and reused! no cracks as such even thought the indentations are stress raisers to a degree in my eyes, will polish these up and stick up for another look later, not sure what affect the marks will have on compression or future issues, one on ebay atm for $60 doesn't seem to have the coil supports on it like mine and seem to have rings gouge's / marks the same as mine....don't wont to spend $200 on a new one unless totally necessary.
Next will be to pull down the motor, will read the manual over first, mate should know some basics on marking things so as to re assemble correctly and not disturb the timing if that's possible.
Will get the leg off and get the water pump and internals all cleaned up ready for refit later also.
