00' Seadoo GTX Limited Info Center Won't Turn Off
Leedanger
Hey guys. I got this 00' Seadoo GTX with an always on info center, even with the dess key off the machine. Someone had run a switch coming off the batt initially to try to eliminate this problem, kind of like a perco switch, but all it did was cause it not to start. So I bypassed that switch so it's back to how it should be and now it runs but the info center still won't shut off. I noticed too that the dess key post is a little loose so I am assuming it has somehting to do with that but idk. If it is the dess key I have to take it to the dealership to get a new one programed right?
Scarter3689
Re: 00' Seadoo GTX Limited Info Center Won't Turn Off
I'd check your start switch. That sends signal to mpem to turn them on
mphy98
If you have another battery try that. with today's cars and computers a bad battery can really make things go crazy. I would bet that could be it.
Leedanger
So it's funny you say that. I've tried several batts in it including known good batts and a brandy new one still the same issue. Furthermore it seems to rev up and down slightly at idle and is definitely not water worthy at the moment. I did replace the solenoid switch inside the coil box with zero effect this way or the other. Lost as a mofo on this fella.
JUL193
Either and MPEM Problem or the info center themselves
