00 Waverunner no air
rheine
Seems like my Yamaha '00 800 XL Waverunner (2 stroke) is starved for air. I am guessing air filter or choke cable. Any other places to look?
Update: I pulled the intake silencer cover off and the case has oil in the bottom of it. Where did that come from??
Rick
Jeff Walkowiak
Re: 00 Waverunner no air
blow by in your reed valves,, you probably need new reeds.
JUSTINTIME
that is normal for that ski
might ned a carb rebuild
rheine
Found the problem, zero compression in #2 cylinder. Ya, that will make it run funny. Here comes the wrenches.
JUSTINTIME
i have seen those motors blow gas in the air when running normal
scottww554
2000 yamaha xl800
2000 yamaha xl800
I have A 2000 Yamaha xl800 Pwc Had new carbs put inn 3 years ago, It starts and runs fine but when it is at full throttel it sometimes wont idle down and keeps running at full throttel , All cable linkages and springs are working fine ,throttel lever pulls back ,but pwc still runs wide open. can anyone help ?
