'01-115 Yamaha Shifting Issue
kriskate
Removed lower unit, Replaced water pump , reinstalled lower unit, started, throtle works, shifting doesnt. Any comments? Thanks.
k4ubr
Re: '01-115 Yamaha Shifting Issue
You Missed The Shift Rod On Installing It ,,or You Moved The Shifter Wile It Was On The Bench. Is The Motor In Gear Or Out, At This Poit.
cousinabe
you have to line up the shift linkage when re-assembling. when pushing the LU together, on that last inch, make sure you line up the linkage gear splines.
kriskate
Thanks for your replies.
I will remove and replace the LU and pay attention to the last inch.
