03 15h 2stroke mercury hard to start and won't stay running
crazyfish73
I took carb off cleaned an out back together aparently fuel or tank started breaking apart and clogged carb...
New fuel lines and tank .. I put 50:1 fuel/oil only way I can get it started is by pulling on lever by flywheel all the way forward but as soon as I let off it shuts down.. Lots of smoke and some blk oily water in trash can where I have motor submerged.. And help will b greatly appreciated... Trying to get it ready for this coming weekend wanna take my boy out for his first time thanks!!!
Bosunsmate
Re: 03 15h 2stroke mercury hard to start and won't stay running
You need to check you are getting spark on all cylinders
crazyfish73
Checked getting spark on both cylinders noticed when pulling plugs lots of blk oil on plugs wet.. Notice lots of oil in water trash can and smoke
Bosunsmate
Check your carbs arent flooding.Does primer stay tight when engine is off?
crazyfish73
Number 1 cylinder not firing
Bosunsmate
Swap your coils see if the problem stays or shifts with the coil
crazyfish73
Doesn't change
crazyfish73
Wait my bad I swapped wires from switch box and it changed... My bad
crazyfish73
Ok swapped coils and didnt change .. I'm thinking switch box?
crazyfish73
MERCURY - ( 15 H.P. (2003 ))
Serial No: 0T618687 Model No: 1015201AD
Can anyone know part# to switch box?
crazyfish73
Thx!!!!
crazyfish73
Ok before I ordered switchbox I checked all grounds started up I can hear spark grounding out somewhere..
So I put my insulated screwdriver on top wire and got it to spark on ground.. Tried it on bottom and got no archs.
I went to auto parts store and purchase 2 wires , installed the wires and the same thing ... I value all my brothers opinion ..
Wht should I do.. I'm lost!!!!
crazyfish73
Ok ima pick y'all's brain..I held spark plug wire around an inch from ground and noticed one bright spark but not constant example: spark.......spark spark.....spark......................spark........spark and this is top plug I'm thinking it should be a more consistent wht do y'all think?
crazyfish73
Can a faulty switchbox do this?
Bosunsmate
Yes it should be consistent. Does it do that with the other coil attached as it could be coil or switchbox
crazyfish73
Yes sir I switch coils and did same test
