03 HPDI Vmax excessive oil consumption?
brownies
Compared to several other Yamaha Vmax engines I've run, this latest one sure drinks the oil, and LOTS of it.
It's an 03 Vmax HPDI 250 2stroke. Only had it a couple of months now and it uses about the same amount of fuel as my 99 Vmax carb 150 motor. But, the 250 uses three times as much oil.
I don't know of anybody with a Yamaha 2stroke that has to fill thier oil tank every 40gal of fuel, but, sure enough....if I top everything off and use 40gal of gas, It'll take 2 gal of oil to fill the tank.
Anybody know how to cure this problem, or, if this is even a problem at all?
Thanks in advance.
JUSTINTIME
Re: 03 HPDI Vmax excessive oil consumption?
they had recalls on the oil pumps
better call a dealer and ask
rodboltw
not only may there be a link rod update but possibly an oil pump and ECU update that is needed.
have your local dealer run your primary ID though and also look for the tech bullitens pertaining to the VZ250.
