My new rig has VRO but came with no remote oil tank. Some prior owner just blocked off the oil line at the fuel connector and started mixing with a understandably poor outcome. The guy I bought it from said He could never keep it running.
I've established the VRO pump is shot, the fuel pump section doesn't even work. I bought a pre '83 fuel pump(part#395713) and am in the process of doing a "Retro" pre-mix reconfiguration, VRO pump removal and carb service today. Questions; What are the wire colors for the remote oil tank connection that needs to be disconnected under the engine cover? Below the lower carb on the intake manifold next to the VRO pulse port there is a brass nipple with a hose just laying there not connected to anything. Does this nipple get blocked off just like the VRO pump pulse port?
Thanks for any help, Larry
