0303714 | SCREW OMC, Johnson & Evinrude
seakas
Replacing the shift rod lever in a '68 Johnson 6hp I picked up a few weeks ago. Anybody know the size (e.g. 8x32) this screw is? Or is it a proprietary screw?
Rick.
Re: 0303714 | SCREW OMC, Johnson & Evinrude
If you tell me where it's located I would be willing to check on my 68 Evinrude 6HP. Perhaps a picture? Best of luck. Rick.
F_R
You talking about the one that holds the inner shift lever to the shifter shaft? I don't have one handy to double check, but I THINK it is 10-32. One thing for sure, it is a hex head and uses a tab washer to keep it from loosening. Stainless steel, of course. I'd say you won't find one at the corner store.
EDIT: Yep, just checked that is part number 303714 as you stated. Tab washer is 303715
seakas
It's the screw that connects the shift rod lever to the shift handle.
I happened to find one in my salvage parts bucket. Thanks for the replys!
68 Johnson After.jpg Here's the finished product.
Rick.
Very nice. You should be proud. Rick.
seakas
Thank You!
