robaloroger
Thread starter- Joined
- Feb 16, 2010
- 123
I am looking at buying a motor. e135fplsrm 2004 evinrude 135hp.. I checked the compression and it was even but all were around 75lbs.. I know alot of the older motors always had low even compression but I am not sure an 04 with low hours should.. Second thing is there are small metal shavings scattered aound the powerhead. Mostly around the starter area. I did not see any holes in the block. I pulled the bottom cowling pan to get a good look but did not see anything.. Anyone see the same on similar motors?
Thanks in advance..
Thanks in advance..
