04 tahoe Q4 - finding replacement rim for spare. Are you kidding me?
fish hook
All I want to do is find a rim and tire as a spare. I've found that the bolt pattern on the trailstar trailer is 5 lug x 4.25" and it is a 14x6 rim which apparently is harder to find than the elusive Bigfoot. I can get the F65-14 tires online but the rim threw me a curve ball - I thought I would simply order a a standard 5x4.5 rim - not so easy. I'm going to try to go directy thru a tracker dealer but i'm sure I'll have to take a loan out to by from them. Short of changing out the hubs, I think my options are limited. Anyone else know where to find these rims???
Husker-Q
Re: 04 tahoe Q4 - finding replacement rim for spare. Are you kidding me?
have you tried the cabelas website - I know they have an assortment of trailer rims
fish hook
i'll give that a try - thanks
fish hook
ok - I feel stupid. I somehow got ahold of a 4.75" rim and thought it was a 4.5" - after researching the net, I found you need to measure from the edge of one lug hole to the center of the other - not center-center. I guess I do have standard lug 5x4.5 pattern on my trailer. Crisis avoided!!
tx1961whaler
iboats sells rims and tires. There is an icon for "Trailer Wheels" right above this thread.
oldjeep
If you need a normal size/load range then cabelas, northern tool or fleetfarm will have you covered. If you need a high load range then etrailer is your best bet.
spdracr39
All the Tahoe trailers I have seen are 5 x 4.5. Better measure again.
fish hook
i used an online template to double check. It is 5x4.5 hub.
