Guys, I have a 05 Aurora 2015 and the breaker /fuse under the "water pump" toggle pops out when I try to turn it on. Is that a fuse or a breaker as if I have a short somewhere ? Also, what is the best fix ?
Check the wireing from the water pump back to the switch and from the switch to the power source. Its either a feed wire to the pump going to ground or the pump wont turn. use a VTM meter and check if both wires on the pump go to ground, one should the other( hot) lead should not.
