05 Yamy 115 2 strk will not cold start.
Chavi
My Yamy will not start unless I prime the Carbs and then it work fine until It gets cold and the priming process has to begin again. I changed the priming bulb and still no worky. Please help
99yam40
Re: 05 Yamy 115 2 strk will not cold start.
primer bulb should be used to push fuel into carb bowls before starting, that priming is a normal process.
