06 F115 won't plane up
jharveyrn
2072 alum. CC, dual tanks. Steady issue for 2 yrs. now and my local marine dealer can't figure it out. Cranks and idles fine, about 3 out of 4 tries to plane up it will start sputtering just before planing up and will not smooth back out unless returned to near-idle speed. If it gets on plane, it will run like a spotted ape all day. We have tried plugs, filter at rear of block, VST filter, fuel lines. Diagnostics were run on the water with it sputtering and no codes. I can sometimes cheat the boat on plane by having everyone sit on the front deck to make it plane quickly before it falls on its face. Frustrating! Thoughts on what to look at next?
Honorary Supreme Mariner
Spend a few coins for a marine dynamometer test.----Find a dealer that has one.
99yam40
not enough fuel to transition from idle to high RPM maybe.
too lean to create the power to turn the prop as it should.
Has anyone monitored fuel rail pressure while problem shows up.
might look at having the injectors tested and cleaned too
