06 SeaRay 195 Sport with Mercruiser 4.3L Questions on Inspections
Harritwo
Just bought a new to me, 2006 SeaRay 195 Sport with the 4.3L and an Alpha I gen II outdrive. Had it inspected by a shop I trust and had the engine tuned, Water Pump replaced, Bellows Replaced and Prop replaced Engine and Gear Box lube oil changed, gear box pressure tested.. Would there be anything else to inspect and/or replace?
Transom is solid, Hull is solid, all electronics work, all gages work, stereo works, canvas in great shape. Engine was tuned and runs good
tpenfield
Time to go boating, if there is any money left :) . If the boat decides that something else need replacing, it will let you know.
