08/2000 johnson 225 smoking a ton???
mboy
Re: 08/2000 johnson 225 smoking a ton???
ok thanks, what would cause a fuel restriction? carb? so what do you reccomend that I do for the old fuel problem? run it as low as possible then fill up? I am not sure what brand plugs are being used I just bought the boat and didnt change anything because the way I was thinking was a motor with 100 hours on it shouldnt be having problems but I guess even a new motor can have problems.
You don't have a new motor. You have an 8 year old motor that was only used for about 13 hours per year.
I would rather have a 2000 motor with 350 hours on it, then less hours.
Outboards like to be run, not sit. BAAAAD things happen to outboards (especially carbed 2 strokes) that are not run regularly.
You would figure 100 hours would be better then 400 hours, but this is not the case.
I hope you sort your problems out.
I would def start with a basic tuneup.
Change your plugs, filters, etc, then go from there.
Did you not get the boat surveyed before you bought it?
If not, lesson # 2 learned.
