09 GT 185 steering issue.....
GregMcQ
Hi all, looking for some knowledge....
2009 Glastron GT 185
There is excessive slack between steering wheel movement and stern drive movement. Inside the engine compartment, where the power steering "rack" is, there are two tubes mounted to a bracket. One of the tubes has the feed from the steering wheel on the drivers side of the boat, its on top. The second tube is underneath and larger.
These two are sliding in the bracket of the whole assembly. I can use my hand and hold them so they dont slide and the slack is gone. I can find no diagram on the rack, and cant see a set bolt, or clip/s to hold things steady and in place.
Is something missing or are things supposed to slide or ???????
brick75
Re: 09 GT 185 steering issue.....
Hey Greg, sorry I can't answer your question, but thought I'd suggest you post this in the general boating section of the forum where many more people would see it since it isn't necessarily specific to Glastron. I'm sure you'd get plenty of advice that way...good luck
