09 merc 50hp 2-stroke
fishon!sc
Took it out Saturday. Cranks up fine. Idle fine. Above 2000 rpm it runs fine but between 1500 and 2000 rpm it will hicup every min. or so. When it does it. It will drop a couple hundred rpm then come back up. I have put new fuel lines and bulb. New pick up in the tank. It has clean gas in it. Any ideas what might be causing this? Thanks.
Fun Times
Re: 09 merc 50hp 2-stroke
09? Do you have any warranty left with mercury? If so why don't you let the dealer play with it for a while.;):)
Good luck with it.:)
fishon!sc
It only come with a one yr warranty. I have had it for almost two yrs. Beside the hicup in the 1500 to 2000 rpm range it runs great.
