COULD COMEBODY TELL WHERE IT GOES?<br />I GOT THE BOOK BUT IT DOE'S NOT SHOW IT.<br />TRENT PLEASE HELP OR ANYBODY ELSE.<br />THANK YOU<br />REX A. HUBBLE
Do you have apicture like that of a 1993 Johnson 60 HP? I hit a rock and it dented in the leading cone and cracked it. I was wondering if I get it welded if there is enough clearance.
rex there are a few pins if i have write model<br />there are two in bottom gear housing front and rear. dowel pin in water pump housing bottom<br />section rear to line up top section of pump housingand one on top of pump hosing that sits on top of spring hope this helps have pic if needed<br />cheers brett.
