1-(909) ***-***x
lakeman1999
I probably knew, but do to senility/old age I have forgotten. What are (909) numbers?? Are they the overseas ripoff numbers?? Or was that (900) or somthing else, as I do not recall. :confused: :confused:
LadyFish
Re: 1-(909) ***-***x
lakeman, I thought 900 numbers were primarily sex hotlines. Don't know about 909's.
mvaughn
lakeman,i think the (909) were the one's in the virgin islands, they would leave a message, something to the effect "family member in jail or hospital" to try to get you to call, then the billing for the call was some 2 or 3 hundred dollars a minute. I guess all you would get if you called was the run around, on hold ect. They had a good scam as they were apparently out of the FCC's jurisdiction? Our co. sent that info to us as a warning, don't know how true it was or is?
Kilgore Trout
909 is an area code in Southern California.<br /><br />It is somewhat of a joke around here.<br /><br />Most of the people in the coastal areas of Southern California equate a 909 area code with Meth labs, Mullets (the haircut) and white trash livng in general
lakeman1999
Thanks friends, I think kilgore trout has helped me, the outfit is supposed to be in California, I think I mistook it for both the sex lines, and the virrgin is. :D :D
Scoop
900 numbers are set up for the caller to be billed at special rates from the company that answers the phone.<br /><br />They can be anything from phone sex lines to support lines. In the IT industry, a lot companies have a 900 number you can call for support if you don't have a support contract or if your software is older and you need support.
