Re: 1 cylinder motor
I need help to identify my 1 cylinder motor. Tag says Sears.
Model # 217-5854-4
Serial # 4A-503665
I don't know anything about this motor. I am trying to get it running. Need tune-up info etc.
Thanks, Xerox
I believe that is a 74 3 hp.built by Eska.It uses a AV520 Tecumseh air cooled power head w a water cooled exhaust leg.champion J13Y plug set at .030.
If it has breaker points set at .020.Solid state parts are hard to come by and expensive.motor is a comprimise at best.It vibrates,is noisy,somewhat under powered,impeller is a weak link, and it requires fiddleing to keep in operation.
It is an inexpensive entry level motor if you don't have to spend too much to get it in operation.
