Compression good, carbs rebuilt, 150 original hrs. Using a spark tester, I found the center cylinder, port side had a weak intermittant spark. Result was loss of RPM at mid to wide open throttle. I replaced the coil and since that did not fix it, I replaced the power pack. That didn't fix it either. I put the power pack lead (that goes to the misfiring cylinder) to a known good coil and got the same intermittant weak spark result. I guess that tells me the problem is upstream of the power pack and has to do with the circuit going to the port center cylinder. My troubleshooting manual does not seem to help. Any ideas?
