Alumarine
Thread starter- Joined
- Feb 22, 2005
- 3,763
Hi there. I have a 1980 #1 Drive serial 565xxx. I split the upper from the lower to change the water pump and it didn't make any sense to me.
I think that the upper is a #1 drive and the lower must be an Alpha.
The upper has the 565xxx serial number on it and the lifting ring on the top cover.
The lower does not have the preload pin, has the square anti ventilation plate and has what looks like a retainer nut under the water pump base.
Do I use the Upper Pump Kit 46-96148A5 (18-3517) with the Alpha Water Pump Base 46-44292A3 (18-3420)?
Thanks for the help.
