10 hp 4 stroke honda
mrfox143
I have a 4 stroke honda 10 hp outboard that won't stay running starting fluid works as long as it is being used stop and the motor dies. model b100s vin# 1502701. what year and where can i get parts for this motor?
any idea how much it is worth?
John
Murp
Re: 10 hp 4 stroke honda
mrfox 143,I had the same Problem,with the same motor,Read my Post,make sure, them 3 Pin holes in the Throat of the Carb are open,use a thin wire,
there for air fuel mix,also check Needle Valve and seat for wear,
psteurer
You most definitely have a carburetor problem and it is likely time for a rebuild. By spraying the starter fluid into the throat you are bypassing the carburetor.
