10 HP Evinrude Sportwin - 1963
jonathanwsmith
Hi -
Does anyone know the part number for the spark plug wire for the 10 HP Evinrude Sportwin? I need two of them. It is a 1963 model.
Thanks,
Jonathan Smith
kbait
Re: 10 HP Evinrude Sportwin - 1963
J4C at .030" is called for,
J6C if you troll all day..
Champion
steelespike
I believe you can get the proper solid core wire and fittings right here at iboats.
And make up your own wires.
jonathanwsmith
Steelespike,
I lean toward make-it-yourself-solutions. Thanks.
Jonathan Smith
Vic.S
Thank you Vic S.
of the four plug wires shown, which would be ideal, the 4", 6", 9", or 12"?
Jonathan Smith
No idea measure up to see which you need. Two different original part numbers implies they are two different lengths.
You can always cut a long one but you cannot lengthen a short one !
cc67
Seeing what's left of your flywheel, plug wires are the least of your problems.
