fucawi
Banned
Thread starter- Joined
- May 18, 2011
- 1,039
WE all k now what a pain it is tracking down a misfire ..pulling plugs and balanceing them on the block ...and of course with CD igniton the switch box is damaged if you crank with the plug leads off ....Every marine workshop has a spark tester with 1/4 inch gaps ....
Take a length of 1 x 3/8 timber and some old plugs you ripped the side electrode off ...drill 2 3 4 holes in the timber and screw in the plugs. Then a length of bent wire ...coat hanger ok to make some 1/4 gaps over the plug electrodes ...crock clip to ground it to the block and away you go .....
Oh yes if the ignition wont jump a 1/4 gap in air it wont jump the plug at cylinder pressure or fire a cold plug when starting
