100:1 gas oil mix ( safe for most outboards)If you use the right oil!
ZmOz
Re: 100:1 gas oil mix ( safe for most outboards)If you use the right oil!
Originally posted by TheOilDoc:<br />I'd hate to see some poor fellow ruin his outboard by ignoring his manufacturer's recommendations and ratios, which is exactly what Amsoil is insinuating he do with this oil. <br />
That's exactly what Amsoil's warranty is for. ;)
Bwalker
I wouldnt hold my breath on collecting a warranty from Amsoil or any other oiol company. You know how hard lubrication failures are to prove?<br /><br />FWIW its common knowledge up here, amongst camp owners that Yamahas last longer when ran at 50:1 vs. 100:1.<br />I actually run most of my motors at 32:1 because I run them hard.
kkj
With a 100:1 mix they will only sell half as much. <br />On the other hand, maybe it cost twice as much?
ZmOz
Originally posted by Ben Walker:<br />You know how hard lubrication failures are to prove?
In an outboard engine it is pretty obvious whether something is an oil related failure or not. If it was an oil related failure and you were using Amsoil at the time, then they pay.
Terry H
There's more "bull" in this thread than you will see in a "rodeo". Chief ;)
TheOilDoc
By LubeDude:<br /><br />Its never happened, and it never will.
With that kind of confidence why don't you recommend it be run at 100:1, and why don't you run it at 100:1 yourself?<br /><br />
By LubeDude:<br /><br />ZMOZ mixes his oil richer than the bottle says, why cant an amsoil user do the same thing.
Well, first ZmOz has a modified and rebuilt outboard (combination of '72 140 and a '74 150). He's somewhat mechanically inclinded and does his own work. Secondly, most outboard owners are fisherman, boaters, or weekend warriors, not oil experts or mechanics. Finally and most importantly, Amsoil's directions say to mix it at 100:1 in any outboard.<br /><br />
By LubeDude:<br /><br />What part of if you run the H*ll out of your engine and you should mix at a higher ratio dont you understand?
That's not what Amsoil says. They say "racing and continuously operated industrial or commercial motors". Most outboard owners don't race or run their engines under commercial or industrial applications. They use their outboards under "normal service". BTW, "higher ratio" means less oil.<br /><br />
By LubeDude:<br /><br />When I used it at 80:1 I was running the engine WOT everywhere I went for two years fishing every weekend and sometimes durring the week.
That is not severe use. Outboards are designed for normal use under WOT extended period operation.<br /><br /><br />
By ZmOz:<br /><br />That's exactly what Amsoil's warranty is for.
Or the Coast Guard Search and Rescue. Outboard failure on the open seas can be life-altering, and when it happens the warranty won't mean much.<br /><br />If you want warranty coverage by Amsoil, you'll have to deal with their following stipulations...<br /><br />"THE WARRANTY MAY NOT BE EXTENDED TO COVER:...AMSOIL RESERVES THE RIGHT TO REJECT A WARRANTY CLAIM FOR ANY OR ALL OF THE FOLLOWING REASONS:"<br /><br />"Failure of equipment due to a pre-existing condition that is unrelated to the use of AMSOIL."<br /><br />Amsoil will claim the outboard had a pre-existing condition that resulted in the failure. You will have to prove otherwise.<br /><br />"Parts inspected do not substantiate a claim or indicate failure."<br /><br />Amsoil makes their own determine if their oil caused the failure. You have to prove otherwise.<br /><br />"Failure was the result of an OEM defect."<br /><br />Amsoil will claim it was the manufacturer's fault. You have to prove otherwise.<br /><br />"AMSOIL lubricants that have been used...in applications where the OEM required lubricant standards do not match those stated by AMSOIL INC. without the written approval from AMSOIL INC.<br /><br />They got you there. OEM's require certified TC-W3 oils. Amsoil's standards do not match that. And OEM's require oil ratios such as 50:1. Amsoil says 100:1. <br /><br />"AMSOIL lubricants used in mechanically deficient equipment as a result of abnormal operation; negligence; abuse..."<br /><br />You'd have to prove otherwise.
timmathis
Tim's here, Been busy helping people fixin broke boats. I didn't really mean to start a battle here. I was just passing on some info I was told by one of my elders. And I know he is a Pro.(With Mercury even) Remember I did not say anybody had to mix at 100:1!!! So calm down and mix at whatever you feel safe with.
TheOilDoc
By Tim Mathis:<br /><br />Remember I did not say anybody had to mix at 100:1!!!
We know you didn't. But that's what Amsoil says to do. In any outboard.<br /><br />"Instructions: SABER Outboard should be mixed with gasoline at 100:1 for normal service in all types of outboard motors"
troska
What is it with people that don't like facts? I welcome every post TheOilDoc puts up on this board because it is a contrast to the constant flow of opinion, hearsay, and BS regarding oils. <br /><br />
Originally posted by LubeDude:<br />Id venture to say that there isnt a TC-W3 oil out there that would hold up as well as the 100:1 will at at the same ratio or even a little leaner.<br />[/QB]
Why would you venture to say this? What facts do you have to back it up? What testing (using proper scientific method) have you done to demonstrate this? How many years experience do you have properly evaluating the performance of oils?<br /><br />For all I know, you have 40+ years in as a marine mechanic. That means you have piles and piles of knowledge about repairing marine engines. It DOESN'T mean you have expertise in evaluating the performance of a 2S oil under controlled conditions.<br /><br />TheOilDoc is not an AMSOIL dealer, does not recommend specific oils, does not profit from any oil being sold over another, has years of DIRECT experience testing TCW oils. Sounds like a good source of unbiased information to me.<br /><br />What is the point of continuing to regurgitate Amsoil marketing garbage?<br /><br />Tim
LubeDude
Originally posted by Tim Roska:<br /><br /><br />Originally posted by LubeDude:<br /><br />Id venture to say that there isnt a TC-W3 oil out there that would hold up as well as the 100:1 will at at the same ratio or even a little leaner.<br />
Why would you venture to say this? What facts do you have to back it up? What testing (using proper scientific method) have you done to demonstrate this? How many years experience do you have properly evaluating the performance of oils?<br /><br />[/QB][/quote]<br /><br />"Why would I venture to say that"?<br /><br />Because I can and I believe it!<br /><br />"What facts do I have to back it up"?<br /><br />None, I just feel it is that good.<br /><br />"What testing have I done"?<br /><br />Well, I have never seen an outboard oil work better than Amsoil in about 25 years of using it, not even close. Never had anyone switch to it that went back to the oil they were using previously.<br /><br />"How many years evaluating oils"?<br /><br />Been around awhile. :) <br /><br />Now, to set this straight:<br /><br />I dont like the Amsoil marketing plan.<br /><br />I dont like the numerous dealers out there that dont know there A*ZZ from a hole in the ground about oils.<br /><br />Im not even very excited about there advertising.<br /><br />I do use and like the products.<br /><br />There engine oils out perform Mobil 1 in wear and oil drain intervals.<br /><br />There gear oils outperform anything I have put them up against.<br /><br />There 2 cycle oils perform better than anything else I have used or investigated.<br /><br />Just my opinion. No science here.
ZmOz
Originally posted by TheOilDoc:<br />Or the Coast Guard Search and Rescue. Outboard failure on the open seas can be life-altering, and when it happens the warranty won't mean much.
Using Amsoil, or even regular oil, at 100:1 is not going to cause a complete failure that would lead to you needing rescue. Increased wear? Maybe. Total failure endangering your life? Hell no.<br /><br />
Originally posted by TheOilDoc:<br /><br />If you want warranty coverage by Amsoil, you'll have to deal with their following stipulations...<br />
Doesn't matter what stipulations they have, an oil failure is very obvious in an outboard motor. When Amsoil looks at the engine they will need to see piston/cylinder scuffing and/or seizure. If either of these two things exist the only explanation would be an oil related failure. There is no way they could try and say that was a pre existing condition or an OEM defect.<br /><br />My engine was run for 10 minutes at WOT with NO oil at all. Upon disassembly, the bearings are all in very good condition, and 4 of 6 cylinders have no scuffing and even still have factory hone marks. (after 30 years!) Given that, I'm sure most any outboard would be just fine running 100:1 on 30w motor oil. Would I do that? No. Would there be increased wear over the life of the engine? Probably. Is your engine going to immediately blow up? No. Doesn't mater what kind of oil you use at what ratio, as long as you have some kind of oil there will not be a major failure. Choosing what oil to use and at what ratio is only a matter of wear over the life of the engine.
LubeDude
Might as well give up OZ, seems that there are others that are just as stubborn as we are. It just seems that rationality just dosnt matter. :confused: <br /><br />Now there is a good quote from me that should get a Quote responce. :D <br /><br />Member LubeDude wrote.<br /><br />" It just seems that rationality just dosnt matter". :p
ZmOz
Originally posted by LubeDude:<br />Member LubeDude wrote.<br /><br />" It just seems that rationality just dosnt matter". :p
:D :D :D
Bwalker
"engine oils out perform Mobil 1 in wear and oil drain intervals.<br /><br />There gear oils outperform anything I have put them up against.<br /><br />There 2 cycle oils perform better than anything else I have used or investigated."<br />Your full of it Lube dude. Most of Amsoils oils are mediocre. HPI is a exception. As far as there oils outperforming Mobil 1. Thats hogwash.<br /><br />ZMOZ, Proving a failure is lubricant related in any engine is very tough. The bottom line is I would not count on Amsoil covering anyhting.
LubeDude
Originally posted by Ben Walker:<br /> As far as there oils outperforming Mobil 1. Thats hogwash.<br /><br />
UOAs dont lie, they will out live Mobil1 every time.
ZmOz
Originally posted by Ben Walker:<br />ZMOZ, Proving a failure is lubricant related in any engine is very tough. The bottom line is I would not count on Amsoil covering anyhting.
How so? Like I said, in an outboard engine, oil failure = scuffed or siezed cylinders. What's so difficult about that? It's very obvious when it happens and there is only one cause.
cpj
Ensign
On amsoil's web site it list's one of their 100:1 oils as being 8 $ a quart so that would be 32$ a gallon.I pay 12$ a gallon for my yammy lube at my local dealer.So at amsoil 100:1 versus yammy lube at 50:1, I would have to use twice the yammy lube for a given amount of gas.Two times 12$=24$.That is 8$ cheaper than amsoil for the same amount of fuel.How is that a bargain?Way I see it,I can use that extra 8$ to by either a 6 pack of barley pop,or 2 extra gallons of gas. ;)
Bwalker
"How so? Like I said, in an outboard engine, oil failure = scuffed or siezed cylinders. "<br /> Many things cause seizures and scuffing besides oil. Air leaks, detonation, improper tolerances, cooling sytem failures, lean jetting, etc, etc.<br /> Even crap oil will not lunch your motor over night in most cases. Its cumlative thing that occures over time. Same thing with 100:1 oils. They wont cause a imediate problem, but in the long run will shorten lifespan.
timmathis
Just to stir things up here is another "QUOTE" from MercMaster "Tim: Sorry about that I was trying to edit my post and accidentally hit delete, Sorry Tim!!! I also had forgotten to mention which "Newc" was so kind to cover for me about how BIA is now the NMMA National Marine Manufactures Assocatition. And yes Mercury Marine didn't have membership with BIA in the 1970's for another reason because they didn't propeller rate there horsepower (Propeller Rated Brake Horsepower) until the 1980's. But all said and done you can use 100:1 with no fear of Piston Ring Stick or Scuff!!!! I have been running Amsoil in my Mercury MOD VP since new, and the outboard has never been rebuilt and I'm running my outboard between 7000 to 7800 RPM's and she runs as cool as a cucumber. I now have changed to Redline and find this stuff is so slippery my RPM Band is now in range of 8150, so I had to swing another propeller to bring my RPM Band down while gaining another 4 miles an hour faster than before doesn't sound like much but if I were racing it would make or brake whether you win or loose. Now I'm not recomending to any one out there to use the same RPM band I'm useing what I do depends on other modifications, to which I for one have access to at Mercury Marine Racing Division.<br />100:1 Go for it, and try it you'll wonder how you got along with out it and if you find it's not for you than go back to ? (50:1) !!!<br /><br />Merc!!! "QUOTE"from MercMaster.
timmathis
And here is a reply to MercMasters first "Quote" that may be interesting to some of you guy's. <br />"Quote" To MercMaster From Newc<br />I need to take issue with a few things that MercMaster had to say on this topic. Not wanting to start a feud, but wanting to give the original poster some additional and different information.<br /><br />First of all a bit of background. I am the original patent holder for the first 100:1 two-stroke engine oil meeting BIA requirements. This was back in about 1974 and was based on the prevalent additive technolgy at the time and a synthetic base stock (oil). One of the tests that was successfully run at that time was the durability test, which was run at the 'worst case scenario' duplicating the conditions of the engine owner only putting one-half as much oil in the gasoline as was recommended, resulting in a ratio of 200:1. Since it is under these sorts of conditions (high speed and load to check for any piston scuffing) that a racer runs his engine - not being too concerned at that point for the long term storage protection at that time - it's not too surprising that some racers have been run at "ratio's like 112:1 and I've heard some messing with 116:1 and 118.7:1 you got be pretty sure of you're self to be going that lean on oil but Redline is different", since other non-synthetic oils will do the same thing - though I don't recommend it.<br /><br />In fact, with the background and experience that I have in engine oils and specifically two-stroke engine oils (40 years), I suggest the very simple expedient of following the manufacturers recommendation for oil quality and ratio, while recognizing that NMMA (National Marine Manufacturers Association which replaced the BIA about 15 years ago) TC-W3 can be used in place of all earlier TC-W oils (TC-w and TC-W2). There is no cost benefit to paying more for synthetic oil and using it at ½ the amount as a conventional 100:1 oil since the synthetic will cost at least twice as much. So why run the risk? Synthetics provide a very valuable benefit in certain applications, but a two-stroke engine simply isn’t one since the oil is a ‘single use’ in that it goes straight through the engine and therefore the low temperature fluidity, high temperature and oxidation resistance benefits of a properly formulated synthetic are not used.<br /><br />As for Amsoil “had too pay a royalty to be able to place that TCW-2 or TCW-3 on there labels to which Amsoil would not do in recent years”, this does not pass a test of reason. The significant costs associated with getting NMMA approval and therefore the ability to display the NMMA TC-W3 trademark (the actual testing and the license fees) are paid for by the additive company that does the testing (Amsoil doesn’t do the actual testing, the additive companies do) for the oil company customer, not by the oil company customer.<br /><br />By the way, a couple of additional comments – Amsoil was a customer of mine when I was with the world’s largest manufacturer of synthetic oils and we were selling Al Amatuzio (the owner) all of his synthetic oils already pre-blended.<br /><br />There’s a possibility that MercMaster may have a it different take on some of the history contained herein, and if so this may be due tohis time with Mercury and therefore being subjected to some revisionist history prevalent within the company. The fact is that Mercury – until they were bought by Brunswick – wasn’t a member of BIA. This was for the simple reason that Carl Kiekhaefer – the founder and owner of Kiekhaefer Corporation, which sold outboards under the Mercury name – wouldn’t accept the concept of becoming part of a trade association since it meant that he would have to reveal his sales figures (that were already publicly available due to state taxes and registrations) to the trade association directly. Despite this, the BIA allowed Kiekhaefer and later Mercury to have a representative (Paul Hobson) on the Oil Certification Committee. Newc
